It is currently Tue Jul 29, 2025 4:29 pm
 Post subject: Cannulated Drill Bits
PostPosted: Sat Apr 11, 2020 4:15 pm
I was an Orthopedic Surgeon and one thing we used in multiple applications was cannulated drill bits. You only get one chance to get a screw in the right place in fracture surgery so we would drill a small guide wire at the angle desired and take a film and if not right you could redirect it and then drill over it with the proper sized drill for the screw which was also cannulated.
I have found some applications for this concept in lutherie where a fairly large hole has to be drilled at exactly the right angle.
To my surprise I found some relatively inexpensive drill bits on eBay. I use a 10mm one for the holes for my 3/8” carbon tube headstock support struts where the holes have to be angled in two planes. I am sure more applications will turn up.
Image1E90A479-C187-4B9B-91DF-908DA4409698 by Terence Kennedy, on Flickr
ImageF021B19B-A447-4ABE-8EC4-EB503290A6CC by Terence Kennedy, on Flickr
Image228AE394-FA2A-4AC4-B027-8673679320C7 by Terence Kennedy, on Flickr
These users thanked the author Terence Kennedy for the post (total 2): Ken Jones (Mon Apr 13, 2020 7:52 am) • Robbie_McD (Sat Apr 11, 2020 5:00 pm)
PostPosted: Sat Apr 11, 2020 7:13 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Yep, that idea makes sense. All you need now is the portable x-ray image intensifier and you will have the perfect set-up. But then you probably don’t want to be wearing a lead apron around the workshop like you used to do all day in the OR?
PostPosted: Sat Apr 11, 2020 7:16 pm
What I really want is a crew to set up the procedure, hand me my tools, and cleanup afterwards :)
PostPosted: Sat Apr 11, 2020 8:09 pm
Funny story: I was coming home from the hospital a couple of years ago after visiting my wife, and I saw a long and narrow drill bit laying on the ground in the parking lot. I had to pick it up and I have been using it for various tasks in my shop. It is the perfect size to drill into the headstock to insert a heat-stick when resetting a neck. However, it does not have a hole in it. Now I know where it came from.
PostPosted: Sat Apr 11, 2020 8:54 pm
I've looked at these in the past, but then I realized that these were accurate within .001" and my usual way was bang on. :)
PostPosted: Sat Apr 11, 2020 9:46 pm
Looks like a good tool for boring woodwinds. Where can those be found?
PostPosted: Tue Apr 14, 2020 6:53 pm
Do a search on eBay for "cannulated drill bits". You will be surprised at the results and in some cases the prices. It seems there is quite a back alley market for surgical tools :)
The 10mm one I have that takes a 3/32" guide pin is one used for drilling the attachment tunnels in the tibia and femur in ACL reconstructions. I would guess a hospital would pay at least $2-300 for one. I got it on eBay for around $35.
These users thanked the author Terence Kennedy for the post: Clay S. (Wed Apr 15, 2020 9:31 am)
